2012 vector engine has flat spot
pvggreenville
I have a 2012 Vector I bought new. It has about three thousand miles on it. I put a new belt on it about seven hundred miles ago. It recently started to have a flat spot when re-engaging the throttle after coasting towards a stop. The engine kind of growls and then instantly comes to life. It does this approximately five to ten times in two hundred miles. Does anybody have any ideas?
Please fill in your location info.
Could be TORS acting up, try disconnecting the TORS and see if still happens. Start with the simple stuff first.
My 2010 does something very similar if not the same as this, first time it happened I thought I had a bad plug and had a cylinder coming in and out, I am now coming to think it may be in the clutches. Still searching.
