Viper S
Is there a simple way to add a couple in. of rise to my handlebars without changing the whole post and cables? I understand that a lot may need to be changed just to get 2 in. more of rise? Thanks in advance!
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
You should be fine using all of your stock cables with just a 2 inch riser, it may require you to reroute the ebrake cable but all others should be fine, i have a new takeoff rox set that i tried but they werent tall enough fof my seat& my height, pic attachedIs there a simple way to add a couple in. of rise to my handlebars without changing the whole post and cables? I understand that a lot may need to be changed just to get 2 in. more of rise? Thanks in advance!
Brotherdan
- Sep 8, 2017
- Belmont,maine
+2" just requires a bit of re routing for the cables and wiring. put the stock riser from my 11 apex on my brothers 13 rs venture to add 1.5" in height on it and had no issues. on my 11 when i added the +3" riser, i only had to run the throttle cable under the bars to stop the tors activation as there was enough slack in the rest for it to fit right.
