wyre345
My wife has a 2014 Apex xtx. In low snow conditions the yellow caution light come on that it's getting hot. But my old rx1 wont get hot in the same conditions. Is the light warning you before it gets too hot??? And I also read that it will shut down before it over heats. Is this true?
- Jun 28, 2004
- Clinton, Wi.
More than likely you've got to high of concentration of antifreeze or an air bubble in your system. I'm coming up on 14,000 miles on mine in all kinds of conditions. Never seen the overheat light. No idea if it'll shut down before completely overheating.
Yes is the answer to both questionsMy wife has a 2014 Apex xtx. In low snow conditions the yellow caution light come on that it's getting hot. But my old rx1 wont get hot in the same conditions. Is the light warning you before it gets too hot??? And I also read that it will shut down before it over heats. Is this true?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
well yes and no if you are running wide open it will not shut down on over heat. I would test the antifreeze and check coolant level as the xtx comes with rear exchanger. Mine was extremely rare to come on if you are running on hard trails you may need a set of scratchers to put down when in low snow.
yes it will shut down on overheat. i have found that when going slow, even with the running boards all packed with snow, the lack of air/snow flowing by the exh will over heat it as well. apex/rx sleds like to be doing at least 30 kph on a packed trail. in the powder it does not matter.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I'm surprised I have not seen an overheat on the XTX. That rear exchanger will get toasty warm though. Many times shes steaming up a storm when it is warm. I did drop on cable scratchers to the skid and drop them when I think I should be getting hot, or running roads. They will fill a skid with ice/snow in no time. It's just so much weight! But the sled is cool.
whitedust1
16,000 miles on my xtx never saw the overheat light go on. Either she is going too slow or hardpak isn’t getting snow to the heat exchangers. My 2007 Attak would throw an over heat light at the oddest times but didn’t have the rear heat exchanger like the xtx.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I have not seen it on my XTX yet, 1st season owning, however last weekend my shorty turned the light on, trails were frozen solid and no scratchers so had to pull over to let cool down once.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
As others have alluded to if there is not enough track speed to throw snow around they can overheat.
They sled will not shut down if the sleds if moving and overheats. The shut down feature only activates if the sled is stationary when over heat temp is reached.
or in my case moving slowly, it shut down and i was doing less than 10kph.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Hmm....wander if yamaha changed logic on later years on ecu. Good to know.
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
2016 Vector XTX. Took my son up to the border. Late in the season year before last. Let him ride the Vector. I rode my old 2 Stroke. Hard pack icy. No scratchers on the Vector. He Stopped and I turned around. I asked what's wrong he said Yellow light flashing and loss of power. I turned on Vector and that's when I learned it had a electric fan by your right foot. So we waited for it to cool off and drove 2 miles back to the trailer. Have Scratchers on it now. For what it's worth.
