Dan T
- Jan 30, 2021
- Kalamazoo, MI
- 2014 Yamaha SR Viper LTX SE
My first oil change by me, in my Viper. Had the shop do it before, wanted to do it myself.
Is the engine oil and the chain case oil the same oil?
I drained the oil out of the engine and reservoir using just the drain plugs, changed the filter, starting filling the reservoir and couldn't see the 1/2 fill line in the window. put in 4 quarts still no line, must have over filled. ran the engine til warm. concerned, i drained the reservoir and ran the engine, found my 1/2 fill line. now i'm concerned about the reservoir being empty?? confused.
lots of research, still concerned.. heading to the UP next week for a 10 day ride, don't need a broken sled...
my first 4 stroke sled! Love the sled, need to learn the mechanics...
thanks in advance for your advice!!
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Engine and chain case are not the same oil. There is not a chain case drain. If you want to change the chain case oil you have to remove the chain case cover that the oil tank mounts to. I usually do both at the same time. Drain the engine and oil tank. Change the filter. While the oil tank is empty I remove the muffler and oil lines to the tank and remove the chain case cover with the oil tank attached and drain the case. Inspect chain, gears, tensioner. If your tensioner screws aren’t tack welded now is the time. If your oil tank is leaking now is the time to reseal it, they are siliconed on but BOP makes a gasket if you prefer. Also check the upper gear bushing for wear. Reassemble with the updated orange chain case cover seal, not the black original one, they leak. Adjust chain tensioner. Then add gear lube to top of site glass about 14oz.
Next hook everything back up that was removed and add 3 1/2 quarts of oil with new filter. Run it till warm and then shut it off. Now check and adjust oil level. You will also want to have a new muffler gasket on hand or get the copper reusable gasket from BOP.
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
Are people having good luck with the copper gasket? It's one if my biggest pet peeves about this sled! My dealer never has gaskets in stock, and they are completely necessary for maintenance.Engine and chain case are not the same oil. There is not a chain case drain. If you want to change the chain case oil you have to remove the chain case cover that the oil tank mounts to. I usually do both at the same time. Drain the engine and oil tank. Change the filter. While the oil tank is empty I remove the muffler and oil lines to the tank and remove the chain case cover with the oil tank attached and drain the case. Inspect chain, gears, tensioner. If your tensioner screws aren’t tack welded now is the time. If your oil tank is leaking now is the time to reseal it, they are siliconed on but BOP makes a gasket if you prefer. Also check the upper gear bushing for wear. Reassemble with the updated orange chain case cover seal, not the black original one, they leak. Adjust chain tensioner. Then add gear lube to top of site glass about 14oz.
Dan T
- Jan 30, 2021
- Kalamazoo, MI
Thanks for the advice!! my mistake was i didn't see the second window on the reservoir! once i figured that out it all made sense.. (2) windows, who would have thought! Rookie mistake..
thanks again for your help!
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Yes, I've had the BOP copper gasket on since my first muffler removal of my 2017. No more replacing the torn factory gaskets! Awesome upgrade, thanks Travis!Are people having good luck with the copper gasket? It's one if my biggest pet peeves about this sled! My dealer never has gaskets in stock, and they are completely necessary for maintenance.
