ryan casavant
- Mar 2, 2016
- thompson,Ct
- 2015 Viper MTX
2008 Apex MTX
2007 Phazer MTX
I have a 2015 viper mtx 153 with fox floats i have replaced the center shock spring with a 160# 3-1/2 turns from slack i legnthen the limited straps 1-1/2 "
im running 80psi in the front and 150psi on the rear i still bottoming out in the rear any ideas what i should try next before i changed the center spring i was at 180psi on the rear did not bottom out but had no ski lift
my original goal was to get more ski lift which i did get
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Maybe your rear shock just need to be rebuild? If so cannondale can help you out with that
Another thing not sure how much tranfer you're expecting but a MTX will never transfer like a XTX does. But it will surely go more places with ease.
ryan casavant
- Mar 2, 2016
- thompson,Ct
- 2015 Viper MTX
2008 Apex MTX
2007 Phazer MTX
I did get the ski lift I wanted what would be the best way to check if the shock needs to be re builtMaybe your rear shock just need to be rebuild? If so cannondale can help you out with that
minks_698
- Dec 21, 2006
- Wisconsin Rapids
- 2016 Viper MTX 141
Unless you weigh over 300lbs, 150# in the rear rear shock seems way high. I run 120ish and weigh over 210. It rarely bottoms and I'm not afraid to jump it - 16 mtx 141. I'd say shock is blown.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
I agree. We run 125# in the rear on my XTX and the kid jumps it all the time. I have riden it in very rough trails and no bottoming. I'm betting you need a refresh on both rear shocks. Center shock is notorious for getting water in it and then it's sacked. I have 4400 miles on mile sled and have had shocks refreshed twice already, and am like new again. Cannondale27 gives great service and upgrades wipers to help keep water out. Price is right too.
alexi
- Feb 15, 2018
- FI
- Other
- SR viper XTX LE Proboost IC
I gave my shocks to KPM tech, specialist in here, they put harder öhlins spring in skid front and shim. Rear skid shim + some part change(pressure valve or something?) and no need so much pressure at all and rear shock isnt so hard because pressure can be dropped and still have even better performance. So give you shock in specialist and enjoy ride!
