MarkB83
- Feb 19, 2018
- Alberta
- 2016 SR Viper MTX 162 SE
2008 FX Nytro MTX 153 40th Anniversary
Hello everyone, new to the forum (although I do check it out from time to time to get info)
I’m looking at changing the connecting rods on my Viper (05/15 build date) and was wondering if anyone knew if the sidewinder rods were an option?
The part numbers are 8KH-11650-00-00 for the viper and 8KJ-11650-00-00 from the sidewinder rods. I’m just looking at alternatives to the $1,100 CDN Carrillos for running 5-6# of boots.
Also has anyone changed the connecting rods themselves and could give a rough time estimate?
Chief Gotta Go
- Feb 14, 2018
- Frankenmuth Michigan
- SR Viper LTX
Maybe I am wrong ....but that would of been a 2016 model year viper . Those all were recalled to replace the connecting rods . As they were breaking off under turbo boost and was very marginal under standard power . Yours should have been recalled and the new rods installed . If not check your dealer right away . The replacement rods are specked to handle the Yamaha /MPI turbo option . The 2016 rods were softer metal and was cast with less metal (Save Weight ) the replacements were a lot harder metal ... I saw the difference between the 2015 viper and 2016 viper rod at a dealer ...the 2016 was a lighter duty connecting rod and the bolt shoulders were less also ......you could easily scratch the metal on a 2016 rod with a file ...the 2015 rod would not leave a mark
BLH
- Mar 18, 2017
- Wisconsin
- 2016 SR Viper LTX-SE
2023 Sidewinder 137
The recall notice I got on my 2016 was clear that the replacement was only an option if turbo...
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Only the motors that had spring ordered the MPI turbo option had the rods replace under recall. The factory rods are supposed to be fine in N/A motors. When mine were changed out, I had (file tested) hardened ones. The new ones were different in shape than the originals.
The sidewinder rods are different than the Viper I believe so they wont be interchangeable as the motors are different. I would do Carrillo's if it was on my dime.
MarkB83
- Feb 19, 2018
- Alberta
Sadly the recall was only for MPI turbo pre-ordered sleds and the NA ones are not part of the recall (here in Canada anyway).
So the replacement rods (new stock) are equipped to handle the MPI turbo kit (190HP)?
I won't make a decision until this season is over, don't want to be stuck without a sled, but the rods will have to be changed in the future. I like the Viper (had a Nytro before) but it is disappointing about the rods, I just want more snap when I hit the throttle.
SwedeViper
- Nov 7, 2016
- Norrbotten
- Sweden
- Viper M-TX 2016 MCX 270
MCX also has their "own" rods for 2016-..... Viper/XYZ.
MarkB83
- Feb 19, 2018
- Alberta
That's good to know! I asked a Canadian MCX distributor and I guess they were not aware.
iam_canadian22
The recall only applied to sleds equipped with the dealer installed mpi turboMaybe I am wrong ....but that would of been a 2016 model year viper . Those all were recalled to replace the connecting rods . As they were breaking off under turbo boost and was very marginal under standard power . Yours should have been recalled and the new rods installed . If not check your dealer right away . The replacement rods are specked to handle the Yamaha /MPI turbo option . The 2016 rods were softer metal and was cast with less metal (Save Weight ) the replacements were a lot harder metal ... I saw the difference between the 2015 viper and 2016 viper rod at a dealer ...the 2016 was a lighter duty connecting rod and the bolt shoulders were less also ......you could easily scratch the metal on a 2016 rod with a file ...the 2015 rod would not leave a mark
Sent from my SM-G930W8 using Tapatalk
My bad should of finished reading thread lol
Janne339
Sidewinder rods are 2 mm shorter than -16 Viper rods. And -16 rods are 2 mm shorter than "Nytro rods"..
The stronger mcx -16 rods works great and are much cheaper than Carrillo.
MarkB83
- Feb 19, 2018
- Alberta
One quick addition. If I put low compression pistons in when I do the rods but don’t add a turbo right away will the motor run like crap?
SwedeViper
- Nov 7, 2016
- Norrbotten
- Sweden
It will run like crap.... but why make the effort and changing rods without mounting turbo at the same time.
MarkB83
- Feb 19, 2018
- Alberta
Money wise it’s quite expensive to do it all at once. Maybe I’ll get everything before I tear it apart.
SwedeViper
- Nov 7, 2016
- Norrbotten
- Sweden
How much power do you plan for?
MarkB83
- Feb 19, 2018
- Alberta
In the end I’d just want the 190hp kit. It would be great to go bigger but realistically 200hp max.
I think I’ll be ok just replacing the connecting rods for that much power. If I want to go bigger I may have to look at a sidewinder.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
just my opinion but it would be cheaper to trade for a sw !
buy the time you buy rods, turbo , clutching. you are looking at around 5000$ Canadian that's if you do the work your self!
then once you get hooked on the power if you are like me you will want more! then you are into buy head shim intercooler injectors (if it mpi turbo pc5 will be required) a additional 2500$ to bump up to 220hp/240hp
