pdrmike
- Dec 13, 2005
- Berlin, WI / Ontonagon,MI
- 12 APEX'S 09 Venture GT
2016 Apex with code 17(exup). When i get it into diagnostic mode i am able to get it to move fully clockwise and fully counterclockwise. (it is showing numbers from 200-207 when i do it)
It doesn't ever return to the center(adjustment area) for me to be able to adjust it.
Any ideas??
Which way is fully open if I decide to eliminate it?
Any ideas??
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
By default if cables broke gravity orients the valve in full open. I make a slick little exup delete plate that locks the valve in open position and also have used exup servo motors. If servo is faulty it will still display fault code even if you lock valve open.
pdrmike
- Dec 13, 2005
Ok, i will keep that in mind. The cables are working fine, but if i happen to disconnect them it will just keep the valve open?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
No, the exhaust gasses will have the valve flopping all over the place in there. You need to lock the valve in the open position or remove the “butterfly” from the assembly. Travis has a quick and slick setup, I’d go that route in your particular situation.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
What stubbs said is correct. Its a cylindrical valve and it will swing around when sled is moving/bouncing down the trail.
My local dealer and I have been working/testing the exup eliminator "foolers" that you install in place of the servo motor. They are in intended to fool the ecu so it believes the servo is in place. They are available for motorcycles, but so far they have not worked in the sleds despite being the same plug.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
once the valve goes both direction's turn power off, it will return to center.2016 Apex with code 17(exup). When i get it into diagnostic mode i am able to get it to move fully clockwise and fully counterclockwise. (it is showing numbers from 200-207 when i do it)
Any ideas??
pdrmike
- Dec 13, 2005
For some reason mine does not return to center.once the valve goes both direction's turn power off, it will return to center.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
my 14 and 16 do, I would get a used servo motor off ebay and try that. The ones from the motorcycles work great, same part numbers.For some reason mine does not return to center.
pdrmike
- Dec 13, 2005
I've got one coming, thanks!my 14 and 16 do, I would get a used servo motor off ebay and try that. The ones from the motorcycles work great, same part numbers.
Cummins6.7pwr
- Dec 5, 2008
- Monticello, Iowa
- 2011 Yamaha Apex XTX
I used this one when I deleted my exup valve and had a bad servo motor. Took care of code 17 flashing on the dash. http://shop.12oclocklabs.com/index.php?route=product/product&product_id=94What stubbs said is correct. Its a cylindrical valve and it will swing around when sled is moving/bouncing down the trail.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
I think I might have to give this one a try, thanks for the info.
