burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
When starting cold, always had to give it a little throttle and then hold the throttle while it warmed up. Then it would be ok for the day. Near the end of the season, it would also stall when coming to a stop. It would start right back up as long as you gave it a little throttle. It was at my dealer in Dec 2019 and I thought he put the latest flash on it. Is there anything else to do to fix this?
2015ViperMTX
- Feb 20, 2019
- Iowa
- 2015 viper mtx
How many miles? Sounds like valves need adjusted.
KillerBee
- Jan 1, 2010
- Waukesha WI
- 2018 Sidewinder LTX LE 50th
Adjust the throttle cable..
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
5,750 miles
aproudcanadian
- Dec 18, 2016
- new brunswick
- 2020 ski doo 900t x
Exhaust valves are getting tight
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Agreed, you need to check your valve clearance
I agree with all you guys. Check throttle cable adjustment first then if that's good Valves.
Also don't forget about old or bad gas. Especially now. Bad gas can easily foul a plug especially one that is on its way out anyway. Get as much of last years fuel out.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
ok, thanks. I'll check both. And drain the gas.
- 7K
