Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Have noticed lots of wear caused by the stock dual spring set up. The plastic slider piece in between the 2 springs causes a lot of wear on the shock body and threads. I have seen others with higher mileage with much deeper wear, and I know some have gone to a single spring. By looking at this set up and running it through it’s motion, one can see that the top spring compresses first and much more then the second heavier and longer spring!
So my question is, can I use the Stingray spring on this shock without causing more wear damage, not only to my shock body, but as some have mentioned, to the shock reservoir? I’ve seen on some older post where some have done this, and or looked into this spring. Clearance measurements between the spring and shock reservoir are much the same between the stock set up and with the Stingray spring!
Also wondering if it slows down the bottom shaft wear at all! At 8K this will be my 3rd bottom shaft counting the original one!
Pics attached for reference !
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
I have been running the Stingray spring in mine for 3 years without issue. After season 1 on my 18 winder I sent shocks out to cannondale for service, he recommended that spring due to wear in shock body from plastic collar. My brother upgraded to QS3R's on his 16 Viper LTX that same year and also has been running the stingray spring without issue. I would say between the 2 sleds we have over 10,000 miles set up this way.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I have a 180 spring in mine I felt the 160 was still too soft, no clearance issues. Cannondale gave me rubber bushings for the shaft wear instead of the stock plastic
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Forgot to mention the shaft, upgrade to the ZR shaft or even better the BOP shaft. We installed the ZR set up a few years back and have not had any issues with wear.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes that is what I should have done this time around, but I forgot all about those shaft upgrades you mentioned!
I did install the Stingray after some testing and comparison on both the stock set up and the stingray!
My very primitive tests of actually putting the shock in the suspension, and manually bottoming the center shock many times, did not cause any damage on shock or reservoir. My thoughts are by observing during the tests, is that the shock body may or would show wear before the reservoir does! Shall check on it after my first couple of rides once the season starts!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Interesting! He does come with lot’s of practical experience with these models!I have a 180 spring in mine I felt the 160 was still too soft, no clearance issues. Cannondale gave me rubber bushings for the shaft wear instead of the stock plastic
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Bop cross shaft or the bdx shaft with wheels (have to look under cat) would be best options
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Site sponsor Krause Kustom Design makes the lower center shock mount shaft.
KKD
I have one season on one and still looks like brand new.
Check out his site. He makes some pretty cool stuff.
KKD
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Krause Kustom Design LLC. | Fort Atkinson WI
Krause Kustom Design LLC., Fort Atkinson. 2,653 likes · 1 talking about this · 2 were here. Located in Fort Atkinson, Wi, we specialize in Solidworks CAD design, Aftermarket billet Snowmobile/m
