paulonedge
Ran fine all week got it home and it wont start . only has 300 miles all fuses seem to be fine . any thoughts? To answer my own question swithched the headlight relay with fuel pump relay , both located in fuse box. Manual said it should have a failsafe mode , mine wouldn't start ? Anyhow in a pinch you can switch the relays, I will be riding with a couple extra .
Turboflash
- Mar 18, 2019
- Southern MN
Can you hear fuel pump run when turning key on?
paulonedge
Yes
I think there may have been some corrosion on relay, sled is a 2017 with only 300 miles been sitting around its whole life until now!Can you hear fuel pump run when turning key on?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Battery?? 300 miles on 2017 sled.. Unless it had a battery tender on it all the time the battery is probably toast.
paulonedge
Yes it is a new battery, old one was toast. Switched relys around and it started, thanks for the suggestion.Battery?? 300 miles on 2017 sled.. Unless it had a battery tender on it all the time the battery is probably toast.
