Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Fired it up two days ago ran perfect and flawless today it will not stay running unless I give it partial throttle, what do you guys think I should do?
Wingwong
- Mar 20, 2018
Did you notice what temperature it was running at?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Have you fired it up to load on the trailer or just short bursts of running in the garage?
The Apexs and RX-1's used to foul plugs doing this and not run well. Plug change and they'd come back to life. You have to let them come up to temp and rev them on the stand good to prevent this fouling.
Fleecer
- Jun 13, 2014
- 2019 SRX
X2....I'd start with changing plugs!!
Wingwong
- Mar 20, 2018
Really it’s a 2 yr old Sidewinder
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Old fuel, not getting up to operating temp, and short trips can foul plugs. Had to replace plugs on a YXZ with 11 miles once. Guy used it to get his mail, never got it warm enough.
Wingwong
- Mar 20, 2018
That’s an expensive mail getter, lol.
**sj**
without complete info , I'll take a shot at it ....belt is high or too short (and too tight)...drop the belt below the sheaves
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Well that's not all he used it for! Ha
sideshowBob
Get it inside and thaw it out...probably just iced up
Dr. FeeLGooD
Sea foam if plugs arent the answer. Actually I would try that 1st.
Doc Harley
- Oct 17, 2016
- Here & there
Well...at first sled was cranking and would not start. Brought the relays in to warm up. Same.
Decided to hold the throttle open a crack. (Like the old days!) Haha. Fired right up. Then off and she died.
With throttle cracked, I got her down off the trailer. Rode appx. 10mins and ran perfect the rest of the day. No answer as to why. But just might help someone else.
Great to come here and get info. Feels good to hopefully help another rider!
Thanks for all replies!
