roadking
- Jan 8, 2017
- minnesota
- Yamaha sidewinder
What should I set the PSI on the Fox rear air shock to for 150 lb. person?
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
There is a free updated fox float rear shock available for your sled if you have the single shot rear suspension, it is way more adjustable and gives you a better ride contact your dealer, for now on your stock shock start out at 170psi and try riding it moving the pressure up or down to suit your weight and riding style it takes abit to dial it in, hope this helpsWhat should I set the PSI on the Fox rear air shock to for 150 lb. person?
mf135
- Jan 31, 2016
- PE
- 2007 Phazer, 2017 Apex XTX
Does this apply to 2016 Vector single shot suspension also? The free updated shock?
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
My understanding is on the 2016 models if you are not happy with the ride then your dealer should be able to talk to his rep and do something for you, there are some that have 2016 models that Yamaha replaced with the updated shock. hope this helpsDoes this apply to 2016 Vector single shot suspension also? The free updated shock?
mf135
- Jan 31, 2016
- PE
Thanks. Will talk to dealer.My understanding is on the 2016 models if you are not happy with the ride then your dealer should be able to talk to his rep and do something for you, there are some that have 2016 models that Yamaha replaced with the updated shock. hope this helps
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
I see in your location that your from PEI is this correct? if so what part of the Island.Thanks. Will talk to dealer.
mf135
- Jan 31, 2016
- PE
Yes, 10 minutes east of Charlottetown, Pownal
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
I am originally from the Island too, Tignish area, moved to NS 35 years ago still have family and lots of friends in that part of the Island, its good to talk to a fellow Islander from time to time.Yes, 10 minutes east of Charlottetown, Pownal
