2018 Sidewinder no spark on mag side cylinder?
Pstn head
Ontario, Canada
Buddies Sidewinder doesn’t start, we have fuel, checked at return fuel line also spark plugs are wet. Probably flooded it by turning it over a few times checkin things for sure but we don’t have spark at mag side cylinder. Swapped coil packs around and spark plugs also but no spark. We have spark at centre cylinder, not sure about pto cylinder (sorry don’t know cylinder #’s) he’s tuned with bigger pump, dash flash, closed loop, 3-bar, Cai etc etc. Prior to this issue he was experiencing hard starts and stumbling starts. He also built a home made Y-splitter to plug in the new to him closed loop system to the accessory plug by the chain case. He’s been having this issue since downloading closed loop and plugging in the necessary hardware associated with it.
Any ideas ?
Any ideas ?
I would baseline the sled by going back to the setup that was working.
-put the wiring harness back to stock
-if it still acts up reflash the sled to the version that was working
