Sly Bourgon
- Nov 1, 2020
- Ottawa, Ontario
- 2018 yamaha sidewinder
I seem to have a vanishing oil issue with my crankcase. No oil on my garage floor, top up went out did about 350km didn't notice oil on the trail and sight glass empty again?
Any known issues?
Any known issues?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Assuming your talking about the chain case? The oil has to be going somewhere? Leaking while your riding as the case heats up? Are you checking the sight glass with the sled on level ground, AND after it has sat for 20 minutes? You will notice when the sled is moving and the chain is spinning around and around the oil will cling to everything within chain case and lower the "level" you see on the sight glass.
Possible that you have a very slight weep hole from a casting imperfection or bad seal that leaks while your riding sled. The chain case temp increases while your riding it.. All the screws around the chain case are snug? Also some have cracked the "ears" on the chain case cover.. These are the tabs so to speak where the screws go through.. Over torqueing the screws can cause this.
Sly Bourgon
- Nov 1, 2020
- Ottawa, Ontario
Thank you for this info, yes sled was on level ground. Yes correct when saying chaincase. Will dig in a little more to see if possible crack in cover. This is great info for me to start looking.Assuming your talking about the chain case? The oil has to be going somewhere? Leaking while your riding as the case heats up? Are you checking the sight glass with the sled on level ground, AND after it has sat for 20 minutes? You will notice when the sled is moving and the chain is spinning around and around the oil will cling to everything within chain case and lower the "level" you see on the sight glass.
SRTGTOCJ7
- Feb 25, 2020
- Jersey/ ADK
- 2023Sidwinder L-TX LE EPS.
2019 Sidewinder L-TX DX
2000 SXR 700
1997 VMax XCT 600
My 2019 is at the dealer now for the chain case seizing up due to no oil. Has only 500 miles. waiting on parts to get it fixed was talking to the dealer, as of now they have no idea where the oil is going. No signs of leaks anywhere. Case was dry. Hopefully as the get it back together they can figure out where it went. Lmk if you figure it out.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Crazy to think the case is dry.. Like no remnants of the oil being in case at all? If it had oil there HAS TO BE some on the chain and gears and or burned onto the parts inside if it got super hot. Not saying your dealer is wrong.. The oil has to be leaking and showing itself somewhere on these sleds.. Unless it was never filled..
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
New sled, first miles??if new probably no oil put in, even if it leaked out it would still be coated with oil, not dry and clean.
