2020 Pics...
ROCKERDAN
OCD Sledhead
Huntsville Ontario & Niagara NY
Other
'18 RTX 50th "Winder"
Some Info and pics....
SRX Black......
No 129" at all again....
LTX LE has elec shocks and 1.25 track...
GT(Red) looks nice with Qs3 shocks fronts/rear....and NOT Electronic
Dan
Same new front end that Tcat has...1.5" taller from top of ski to bottom of lower A arm,New upper A arm also.....maybe they finally got the sway bar to not rub on panels after 8 yrs!
with this kind of pricing yamaha must not be trying to gain riders.
The SideWinder(and T-Cat) are still by far the most fun money can buy for the type of trails I ride.
No other manufacturer has something I desire more because they simply cannot be reliably brought up to the insane power levels of these machines.
There will be plenty of whining on this website(nothing new) that Yamaha hasn't brought out enough new iron this year, but the same can be said about all the manufacturers. You could actually argue that Yamaha and Cat made more changes than Pol or Doo.
Have a great day. :)
What a disappointment. At least new owners will have the long list of improvements necessary to make the sleds reliable from this site. Use their yamabucks to stock up on belts!!
Sadly the cat DNA and terrible quality control will always haunt these sleds.
I thought cleaning the pipeline last year meant a new Japanese sled.
Guess that was wishful thinking!
SRX Black......
Dan
View attachment 147045 View attachment 147046 View attachment 147047 View attachment 147048 View attachment 147049 View attachment 147050 View attachment 147051 View attachment 147052
Yes non electric Will lower the 2020 Model front end over the 2019 model.
Should be a bit faster
Also All new 600cc 2 stroke is available at Yamaha in Canada (the European Transporter)
The rear suspension on it is amazing, able to back up a hill now.
I could see Yamaha coming out with an early 2021 Japanese model using the 600cc 2stroke from CAT. Your right, This may be wishful thinking.
I see it has TEAM clutch leading me to believe its a CAT engine... I dont see any info that says this is a YAM built 2s engine, did you?
Grrrrr
Dan
Did anyone catch the info on new turbos.....
High Tech Turbo
The Nickel alloy turbine body is extremely strong and precise, able to withstand highly elevated temperatures. Supported by premium, ceramic ball bearings, the Inconel turbine blade assembly is very light and strong. This yields a low moment of inertia for lightning quick response to exhaust gas input. Triple throttle bodies are used exclusively to further enhance the quick delivery of compressed air from the impeller to intake valves.
