rtx moose
- Jul 31, 2014
- WATERTOWN,MN
you want to see the new 4 stroke they built,watch the video..they made the 1049cc engine 40%smaller physically..no gear reduction needed!!!!
https://www.youtube.com/watch?time_continue=4&v=BA7k6giVL0c
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Shows how much I follow Arctic CatThese are not all new. The CTEC2 600 was announced in spring of 2013 and released in 2014 models. The CTEC2 800 has been in a couple model years already. Unless they tweaked a few things, these should be the same solid engines as the previous years. These motors that come out of the St Cloud, MN plant are no ETEC on efficiency and oil economy, but much better than the old Suzuki motors. At least you can follow them without coughing in your helmet. But they are still first in the pack......... to the fuel pumps.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
The 1049cc engines never had gear reduction that would be the Apex 998 4 cly screamer . The old motor in the Nytro's ,Viper's , and Vectors where specifically built for snow with lower RPM'syou want to see the new 4 stroke they built,watch the video..they made the 1049cc engine 40%smaller physically..its new 2020,no gear reduction needed!!!!
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
what @rtx moose is referring to is 3-cyl engine used on the Yamaha jet boats. There is a 1049cc 3-cyl engine used on some of the 21-ft boats that is referred to as the TR1 engine used since about 2010. It is essentially the old Nytro motor converted for marine use. The TR1 engine replaced the previously used MR1 engine, which was a 4cyl 998cc engine with gear reduction (aka Apex motor) which was used from 2003-2009. The only other engine used in Yamaha jet boats is a 4cyl 1.8L (no gear reduction) in both NA and supercharged versions.The 1049cc engines never had gear reduction that would be the Apex 998 4 cly screamer . The old motor in the Nytro's ,Viper's , and Vectors where specifically built for snow with lower RPM's
theCATman
- Feb 19, 2007
- WI
- Yamaha
And that video was from 2016. They're talking about the 1049 like it's something new, well, it was for the PWC market.
This has nothing to do with 2020 sled engines.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
point being they can do just about anything and master it..the apex 998cc 4cyl was very old technology
The 4 cylinder first used in the watercraft wasn't a high output engine like the Apex. Then came along a higher output 4 cylinder version with 1050cc's that had 160hp. Years ago I had hoped that Yamaha would've bumped the Apex up to this displacement, but alas, they of course stood still.The 1049cc engines never had gear reduction that would be the Apex 998 4 cly screamer . The old motor in the Nytro's ,Viper's , and Vectors where specifically built for snow with lower RPM's
markyb
- Feb 6, 2015
- Twillingate, NL
- 2009 Nytro XTX
- Twillingate, NL
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
New headlights maybe???
It's an Arctic Riot Yamaha snowmachinethingi
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Where did you find thatView attachment 146763 Looks like a whole lot of BNG to me...
TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
At least this year they didn't spend a Ton of money to show us nothing, unlike last year !
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
The tunnel looks short, maybe a 129”
Not a chance, they just got rid of it.The tunnel looks short, maybe a 129”
markyb
- Feb 6, 2015
- Twillingate, NL
- 2009 Nytro XTX
- Twillingate, NL
Both Yamaha Snowmobiles and Yamaha Motor Canada
- Status
