100MPH
- Oct 11, 2024
- Badger State
- 2020 Yamaha SRX LE
2004 Yamaha RX-1 L
2003 Yamaha 700 SX Viper ER
1997 Yamaha 700 SX
1994 Yamaha V-Max4
1991 Yamaha Exciter2 LE
1983 Yamaha Bravo
Part #8JP-H3755-00-00 Speed Sensor
Replacing the driveshaft and pro side bearing on my new to me 2020 SRX LE and I am wondering what to expect to get the speed sensor out of the driveshaft. I appears to be pressed in? Shaft is still in the sled. Any insight to remove this sensor would be appreciated.
2020 SRX LE 3,900 miles will be addressing:
New driveshaft and bearing (.020" of play in stock parts)
Adding BOP driveshaft saver
Adding DMC 21 tooth drive sprocket (bushing shot)
Tensioner tack weld screws
Adding BOP Oil tank gasket just because
Thanks again for all of the knowledge that is shared on the TY4Stroke Forum
Eddie
Eddie
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
It just pops right out. It's like a ribbed plug, easy peasy.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Use a broom handle or the likes , stick it in driveshaft and pop it out. Drive shaft is hollow
100MPH
- Oct 11, 2024
- Badger State
2004 Yamaha RX-1 L
1997 Yamaha 700 SX
1994 Yamaha V-Max4
1983 Yamaha Bravo
That is what I was thinking. Reassurance definitely helps when tackling these projects.
Thanks for the feedback.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
For piece of mind I used some high temp silicone when I reinstalled mine.
MS
MS
- 8K
- 10K
