Waterdog
- Feb 14, 2023
- NB
- 2020 Yamaha Sidewinder SRX
Anyone having issues with the rear suspension mount rivets coming out constantly? I have re-revited it several times and they just keep pulling out; even tried washers on the backside of the rivet. I know of another SRX and Sidewinder LTX that have had the same issues. I don't have anything heavy on the back of the tunnel, just a Yamaha bag with a few spare belts. Last night after just putting new rivets in 2 weeks ago, I decided I was going to use 1/4-20 bolt and acorn nuts to hold it together. Does anyone see any issues with that?
Fords4life
- Dec 7, 2021
- South Dakota
Any kind of bolt and nut setup i would use some blue or red locktite.
Waterdog
- Feb 14, 2023
- NB
Used Red loctiteAny kind of bolt and nut setup i would use some blue or red locktite.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Did you use air riveter with rivets from oem source, proper rivets
Waterdog
- Feb 14, 2023
- NB
Used air riveter, didn’t use oem, but did try steel rivets also. Still pulled throughDid you use air riveter with rivets from oem source, proper rivets
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
Are you talking about the drop-loop mount? Could you post a picture of where you're talking. I have the same sled and would like to check it out. Thanks.Anyone having issues with the rear suspension mount rivets coming out constantly? I have re-revited it several times and they just keep pulling out; even tried washers on the backside of the rivet. I know of another SRX and Sidewinder LTX that have had the same issues. I don't have anything heavy on the back of the tunnel, just a Yamaha bag with a few spare belts. Last night after just putting new rivets in 2 weeks ago, I decided I was going to use 1/4-20 bolt and acorn nuts to hold it together. Does anyone see any issues with that?
Waterdog
- Feb 14, 2023
- NB
Not near sled right now. It's where the bracket (circled in red) attaches to the tunnel. The rear suspension pivot arm attaches to it.
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
Thanks again. Just went out and checked mine, All good so far.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Are you using washers with the rivets?Are you talking about the drop-loop mount? Could you post a picture of where you're talking. I have the same sled and would like to check it out. Thanks.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
If the rivets keep pulling out, are the holes still the same size? Have you tried stavex rivets?
Mototown
- Sep 11, 2018
- Apex 40 th
Yamaha had bigger rivets for the old trailing arm mounts they may on the foot rest , they may work good
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
How is this working out for you ? I may have to do the same thing, mine keep pulling out as well! Tried a few different style rivets. Looks like you cut back the bumper a bit to install? I know a lot of those holding the bracket in are 'blind' because they go into the bumper itself
