Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
I have a 21 Thundercat with TD jukebox and usually run around 280-300 horse tune most of the time. Last time out I blew 3 belts in 30 miles. Right now it has 73 gram Dalton weights loaded to 78 grams, stock primary spring, Ron Ward torsion conversion in the secondary, XS829 or 827 Ultimax belts, 21/37 gear and 1" ripsaw studded track. Snow conditions have been loose, but would 21/37 gear make it that hard belts?!?
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Oh ya! you can gear up a bit from stock, but not that much (if you expect good belt life)
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
I should add that our trails are like super highways. Its nothing to cruise at 80-100 mph and squeeze it into the 130 range.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
I ride the UP of Michigan, mostly RR grades
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
K, thanks. I have a sled trip planned but don't want to blow belts the whole trip.I ride the UP of Michigan, mostly RR grades
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
I'd pull the clutch off and make sure stub shaft hasn't moved.
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
I did, and checked clutch alignment. It's spot on. I've put about 600-700 miles on my sled with it geared this way and haven't had an issue until now but the trails have been fairly firm until last weeks snow. I'm having a hard time believing that gearing is causing my issue but I haven't found anything else. I have about 1,300 miles on the sledI'd pull the clutch off and make sure stub shaft hasn't moved.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Any chance you have springs binding? I’m not familiar with the Team on the thunders. But any spring binding at all with this power will eat them belts.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Temp check those clutches with your hands also. Betting one OR both of them is running HOT
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Just by touch, the belt feels the hottest, the secondary is also very hot and the primary feels the coolestTemp check those clutches with your hands also. Betting one OR both of them is running HOT
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You got a torsion secondary? Try wrapping the spring tighter. You should be able to hold hands anywhere on either clutch. Sounds like your not balanced so to speak. Primary is pulling belt through secondary?Just by touch, the belt feels the hottest, the secondary is also very hot and the primary feels the coolest
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Yes, it's a torsion conversion in the stock secondary clutch. I'll try the next tighter hole and see what happensYou got a torsion secondary? Try wrapping the spring tighter. You should be able to hold hands anywhere on either clutch. Sounds like your not balanced so to speak. Primary is pulling belt through secondary?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Call Ron Ward and ask him his thoughts on your secondary. From everything I've heard he's a good guy and will try to help you troubleshoot.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
geared on the high side but don't think that is your problem. and even if alignment was off a bit 3 belts in 30 miles is crazy so must be something else going on. I would have a good look at your clutches, take off sled and take apart if needed something is up.I have a 21 Thundercat with TD jukebox and usually run around 280-300 horse tune most of the time. Last time out I blew 3 belts in 30 miles. Right now it has 73 gram Dalton weights loaded to 78 grams, stock primary spring, Ron Ward torsion conversion in the secondary, XS829 or 827 Ultimax belts, 21/37 gear and 1" ripsaw studded track. Snow conditions have been loose, but would 21/37 gear make it that hard belts?!?
- 215K
