shawnj
I know this been discussed before, did a bit of a search but on my phone out in snow bit difficult. This is the first I’m getting to try my sidewinder out. A 2022 ltx le 137”. Bought it with 1080 kms on it so pretty new. I thought I gone over sled pretty good but now I’m away for my first trip and sled is sitting pretty much on torsion blocks. I have them on stiffest setting. I have a Kimpex 2 -up seat and my girlfriend and I made it 2 mins and it sounded horrible. Like something grinding when bottoming out. So we come back and I installed the taller plastic spring blocks that the front of spring slides through, put torsion blocks back on stiffest and want to try again but it looks like it’s sitting on torsion blocks still with no one sitting on sled.
Any ideas out there as I’m 4.5 hours from home and was so looking forward to trying this sled this year.
Thank you.
Thank you.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Is it possible that your shock is frozen limiting travel.
Find a pail of hot water and pour it slowly on rear shock with sled tipped on its side
If not that I would think your shock needs work
no1b4me
Post pictures of your skid and spring position
acpantera
I put a kimpex seat on too (22Tcat), you're going to need heavier springs. Cat part #'s 1704-561/560(real stiff when riding solo).
For now you could try turning the transfer blocks to the thickest spot and put way more preload in the center shock spring. I also put in Yamaha 4 position torsion spring adjuster blocks.
acpantera
Oops misread , bottomed out, no one on it... didn't bend the tunnel?
Mototown
Rebuild your 2 rear shocks , & buy stiffer rear springs
I wouldn't use the taller spring blocks as when the suspension bottoms the inside of the track will be in contact with them.
Also, if you are two-upping you need to buy an aftermarket front cross shaft as it will likely break. This sled is meant for solo rider(factory set for about 180-210lbs total) so you're going to have to make changes.
Rebuild on a 22 with 1100 kms?Rebuild your 2 rear shocks , & buy stiffer rear springs
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Your gonna have to get a 2 up sled or buy her one, just saying. It will suck if you ride alone
acpantera
My Tcat with the right springs makes a great 2up sled. I can change the rear springs in about an hour.
acpantera
OP has an issue with the suspension not returning after compression with no load on the seat. He is on a trip and is in a bind.
shawnj
No shock was free. First time I e had it out of my storage.
shawnj
Ya I can see needing stiffer springs if I were to double more than once or twice. However, it was sitting low with zero weight on sled. Lift it up and fall flat on its arse lol.I put a kimpex seat on too (22Tcat), you're going to need heavier springs. Cat part #'s 1704-561/560(real stiff when riding solo).
