Bigblue1
With 4,200 miles on sw nowwhat should I be looking for to replace/service; Drive shaft and clutch bearing...chain case.......?
number1kyster
I would replace the bushing behind the top gear.
Pstn head
Top gear replace (bushing possibly worn), if no adjustment for chain it may be stretched and need replaced, inspect inside chaincase for wear. Clean and regrease or replace upper and rear idler bearings, jackshaft bearing behind secondary, lower driveshaft bearing behind brake rotor. Go through rear skid for any bushings/spacers for wear, basically common seasonal maintenance, if planning or possibly achieving same mileage next year.
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
How does the jackshaft bearing in the chaincase stand up. Was a problem in early Vipers, had one go in 8000 kms on my 2014, my friend's 2015 went at 7000 kms.My Sidewinder now has 7500 kms. wondering if I should be replacing this bearing now.
Bigblue1
Top gear replace (bushing possibly worn), if no adjustment for chain it may be stretched and need replaced, inspect inside chain case for wear. Clean and regrease or replace upper and rear idler bearings, jackshaft bearing behind secondary, lower driveshaft bearing behind brake rotor. Go through rear skid for any bushings/spacers for wear, basically common seasonal maintenance, if planning or possibly achieving same mileage next year.
Thanks. Kind of what I figured. Was hoping not to have to get into chain case.
