4th wheel install
FXMAN
sharon springs NY
ok so I got my 4th wheel update, and am having difficulty in installing it, I have tried every which way to install the spacers and no luck so far. I have the the 2 smaller spacers, the 2 medium sized (1 5/8") and then he longer one that come with the kit. does anybody have pic's of how there supposed to go? also do you use the washer's that were originaly there? I'm realy getting frustrated here, any help would be great.
thanks ryan
FXMAN,
I assume the 4th wheel kit is sold to fit many different models. Hopefully it came with a spacer the same size as the short one on the left side between the rail and the 3rd wheeel. The spacer the same size as the stock one would be the right spacer between the rail and the new 4th wheel. The long spacer would now go between the 3rd and 4th wheel. I would think you would want to keep the washers on to spread out the forces against the rails. This is my 0.02 but I have not installed one of the kits, so this may not be the case. Good luck.
http://www.portyamaha.com/fiche_image_p ... SPENSION+1
Not sure if this is any help.Installing this would be difficult but not impossible with skid in sled.Like 08rtx said its put together exactly the same as the original side which has two wheels.Copy that to the other side.
sorry to be a pain in teh azz but could you please take the pic's again without the snow?? thanks ryan
here you have a pic
ok, thanks for that pic, but I was trying to get a pic of how the spacer's go, like I said, Ive tried everywhich way, and they dont seem to want to fit. thanxz
Sorry only way to take a good pic is to take skid out.Will look around for a pic like that.
Here is order of it.Measurements are approximate since I cant get anything in there to measure accurately.Also notice adjusters are on a angle so you can get at them through track window.
Looking at back of sled with bolt head to the right.
Wheel,1.5in spacer,washer,rail,washer,adjuster,1in spacer,wheel,4in spacer,wheel,1in spacer,adjuster,washer,rail,washer,1.5in spacer,wheel
