09nytro
What's his facebook pageNytro40th said:He mentioned it on his facebook page I believe
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Ulmer racing
09nytro
I've search that but didn't come up , o-well I'll find it
Nytro40th
- Sep 19, 2007
facebook.com/pages/Ulmer-Racing/191754647571710
09nytro said:What do you mean by solid axle ?lapster said:Is ulmers a solid axle?
None of them will go though the rail because the slot where the axle would go though is to small so you will have a solid axle in the mid and spacers and two wheels then on the outside you will have spacers longer bolts and two wheels , so any kit out there that replaces the tri-hub is a great kit .
The one I got is a solid axle which goes all the way through the slot. Check it out in previous posts and here installed.
09nytro
Wow that's nice !
Who makes that one ?
Larson Racing. Found out about them from a AC XC racer I help.
09nytro
Very nice I must say !
I'm looking at Belanger racing ones to , it looks like he has the track adjuster coming in the other way ( from the back ) that one looks very nice too !
DeerHuntr
Can you post a link to them?
Yamacat21
Just wanted to revive this thread, anyone have any real ride time with these kits? Reviews and install notes would be appreciated.
350 mi and not even thinking about it. Thats good! Install can be done with skid in but would be a pain. I removed the skid since it is so easy.
franklin
I actually machined the rail to 20mm then put in a 1 piece axle with spacers and wheels on it
2lapsdown
Not sure about the other kits, but the Larson Racing kit is the one serious racers use. I worry about a lot of things, but never Dean's stuff. Cannondale is right, drop the skid and do whatever you need to do. It is stupid easy, and fast.cannondale27 said:350 mi and not even thinking about it. Thats good! Install can be done with skid in but would be a pain. I removed the skid since it is so easy.
lapster
- Oct 24, 2011
I went the the Larson Racing axle kit as well. thanks for the info here guys.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
4 wheel kit
YamahaTim said:sk-rx1 said:Just a note for those shopping wheels. I had thought that the RTX and LTX had the same wheels, the XTX the larger wheels. Learned today that the RTX has the smaller wheels, like 7 1/8, both the LTX and XTX have the larger wheels.
I was looking at arctic cat 4 wheel kit and it says 8 inch. Will these work with the ltx se that you say it is 8.4 inches. Did arctic cat just round the the number to 8 ?
I think the XTX and LTX is 8.4 size wheels
