SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
I have blown 2 belts in the 500 miles I have had the sled. When I bought it, I set offset to 58 or 59mm, I don't remember which. Now after the 500 miles and 2 belts I am measuring a 64.2mm offset, after removing the circlip I am only at 63mm offset. Checking with a mirror the bolts behind the primary are not rubbing and appear to have a fair amount of clearance (Likely around 1.5-2mm of clearance). I am planning a 5 day ride starting next week, so ideally I would be able to fix this tomorrow.
How much can be removed from the back side of the secondary before the moveable will hit the bearing bracket there?
Secondly, would you guys recommend machining the secondary or trying to fix the stub shaft first?
EDIT: Clarity
EDIT: Clarity
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Stub shaft first
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
Stub shaft first
Well, I guess is there anyone in the central Wisconsin area with a clutch puller they would be willing to sell/rent/loan out? Doesn't look like anyone is open that sells one tomorrow.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Sounds like the stub shaft has moved big time.
Fix it first. It's just going to keep moving.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
It wouldn't surprise me, the second belt I blew was WOT @ 8900RPM and ~115mph. I don't even want to know how hard the primary slammed shut before the rev limiters kicked in. (I did let off the throttle immediately after the loud bang the belt made blowing)
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
SidewinderConvert, I realize you have offset issues to work out, but what kind of belt are you running? Just curious.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
8JP, Seriously thinking about swapping to the new gates red-line belt though.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Many of the knowledgeable members on here are running the XS 825 belt. Once I got my offset and clutches better dialed in, I've been running that belt with no problems at all. But, it doesn't matter how great the belt is, if you're tuned and running 60+ mm offset, you're eventually going to blow the belt.
- 34K
- 9K
