Wide *******G Open!sorry for the dumb question, what's "WFO?"
attak_rider
- Nov 28, 2014
- Ann Arbor, MI
- 2006 yamaha Apex ulmers clutch kit, air box mod, power commander, reinforced rear susp. pioneer performance tuned shocks
2015 yamaha sr Viper Ltx se, Hurricane 190 turbo kit, ulmers clutching, osp adjuster with 8dn, axys rear and center shock, slp mohawk skis
ha! got it, but then won't you be further away from the powerband? or is that just the compromise I gotta make?
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
I am also experiencing lots of belt dust with my 8dn and when I ran the 8jp... I tried heavier secondary spring to get more squeeze but that made it hotter then I blew the 8dn.
Where are you running now? With belt change it will drop about 200rpm Maybe you will find it goes faster even with lower rpm but if it doesnt just remove some wieght from primary to get what you had back. If your belt was slipping you may not even know what your true Max RPM is right.ha! got it, but then won't you be further away from the powerband? or is that just the compromise I gotta make?
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
I think i am going to try a new 8jp but i am also curious about the dayco xtx
jeffgilbert
- Dec 17, 2007
- Newfoundland
i switched belts looking for a little more top end put found i am getting the exact same speed around 145km/h with the 8dn but much more dust but saying that i found after about 800km the 8jp with done after hard use it was inconsistent put a new belt on and it would be just like new for another 800km this sled spends more time on the back bumper then on the ground with alot of wot on the ponds so i don't expect to get forever out of a belt.
yamagone
- Dec 17, 2008
- Essex, Ont. Canada.
- 18' Sidewinder
I'm seeing the opposite with the 8dn belt dust issue. I still get some but nothing even close to what I was seeing running the 8jp. I'm running Ulmers machined secondary for the 8dn with a red spring and a 2/2 twist. It's a definite improvement over stock. I ran it down a dirt road with minimal snow coverage, more like an ice layer and did get 101 mph ( on Garmin gps) and felt like I could have run faster but ran out of room.
jeffgilbert
- Dec 17, 2007
- Newfoundland
I just picked up a new 8jp I'll clean the tunnel and try it out for 400km same as I got the 8dn on for and see if there is a difference in dust
Same here. Is reason I switched. I had 5 8JP belts and thought I was set for life. 500mi later big time belt dust,black clutches and very inconsistant. Change belt clean everything up and good to go again. 500mi later same thing.i switched belts looking for a little more top end put found i am getting the exact same speed around 145km/h with the 8dn but much more dust but saying that i found after about 800km the 8jp with done after hard use it was inconsistent put a new belt on and it would be just like new for another 800km this sled spends more time on the back bumper then on the ground with alot of wot on the ponds so i don't expect to get forever out of a belt.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I have a brand new 8dn I am going to use. How long do I have to be nice to my belt before WFO runs ?
Wash and dry it. I usually go 10 mi easy and have had good luck!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Wash and dry the belt before I use it? Or the clutch?Wash and dry it. I usually go 10 mi easy and have had good luck!
Belt. But never hurts to have a clean clutch.
jeffgilbert
- Dec 17, 2007
- Newfoundland
Ya that's the most I was getting out off them was 500mi I'm sure the 8dn will last longer but I don't like the slipping I'm getting I think I'd rather replace 2 8jps every season then losing speed/power from slippage
jeffgilbert
- Dec 17, 2007
- Newfoundland
What do you wash the belt with?
- 6K
