Wobbie
- Nov 5, 2019
- Braeside
- 15 Vector
So, trying to be a little pro-active in the off season I ordered up some Yamaha bushings for my a-arms ('15 Vector).
From the Yamaha parts lookup I get 90381-16N51 for the lower inner. Bought from Yamaha but they are too big. Looked up for other years and tried Apex but all of these chassis seem to call for the same parts. Mine are in a bag from Yamaha with the correct number but are substantially different from what is on the sled.
NEW OLD (mm)
I/D 16.35 16.3
O/D 21.23 18.0
L 15.7 12
Now, before I went to the oillite I would have to understand why the "factory" part in my sled is so different from the Yamaha replacement part.
Anyone have any thoughts?
NEW OLD (mm)
I/D 16.35 16.3
O/D 21.23 18.0
L 15.7 12
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Is it possible your sled is actually considered a 2016 which uses a different bushingSo, trying to be a little pro-active in the off season I ordered up some Yamaha bushings for my a-arms ('15 Vector).
NEW OLD (mm)
I/D 16.35 16.3
O/D 21.23 18.0
L 15.7 12
theCATman
- Feb 19, 2007
- WI
- Yamaha
What is the date stamped on your tunnel tag?
I'd bet Brotherdan is correct.
Wobbie
- Nov 5, 2019
- Braeside
- 15 Vector
No, It's a '15 alright. I just wasn't looking hard enough.
When you do the online lookup for the "ski" drawing you won't see the parts for the bushings in the bulkhead. That's the confusion.
Basically I had failed to order the other 8 bushings.
My bad. Thanks, though.
