littledawg
Changing my 2016 SRViper Mtx to a trail sled. Wanting a 42" inch stance do I need to change uppers only or do i need to change everything i do have the old style spindles and A-Arms off a Cat but will need shocks as mine are 16 inch and will need 18.75 if I use these I've read that some say I just need to change the uppers and can keep the original shocks ? Doesn't make sense but thought I'd ask the question lots of talk on here but no real definite answer.
Clamb
- Oct 2, 2016
- Peoria IL
- 02 Sx viper Er 15 sr viper xtx
- Peoria il
You will need both upper and lower a arms and new shocks for the 42 front end
littledawg
Thanks for the info, I researched it yesterday and searching part numbers and making phone calls I got everything ordered. Thanks for your reply.
“shpecial”K
- Jan 15, 2018
- Jackson Mi
- 2015 Viper M-TX 153
- United States
You will also need tie rods and a sway bar if you choose to put one on, the 42" lower arms will have mounts on them.Changing my 2016 SRViper Mtx to a trail sled. Wanting a 42" inch stance do I need to change uppers only or do i need to change everything i do have the old style spindles and A-Arms off a Cat but will need shocks as mine are 16 inch and will need 18.75 if I use these I've read that some say I just need to change the uppers and can keep the original shocks ? Doesn't make sense but thought I'd ask the question lots of talk on here but no real definite answer.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Have you made this change yet? I Have a 15 xtx I could swap parts with you shocks and all, except SwaybarChanging my 2016 SRViper Mtx to a trail sled. Wanting a 42" inch stance do I need to change uppers only or do i need to change everything i do have the old style spindles and A-Arms off a Cat but will need shocks as mine are 16 inch and will need 18.75 if I use these I've read that some say I just need to change the uppers and can keep the original shocks ? Doesn't make sense but thought I'd ask the question lots of talk on here but no real definite answer.
