Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
I'm trying to get some summer maintenance done. I replaced the plastic gauge pod/headlight cover that cracked last winter.
Anyone know the paint code that Yamaha uses for the red A arms? I'm starting to loose some paint I see....
MitchRS
- Sep 20, 2022
- 09 RS Venture GT
I'm pretty sure the paint code is 0918 - Deep red metallic but it would probably be pricey to have that made. Canadian tire has Dupli-color Metalcast spray paint in deep red which looks like it would be a close match. I'm hoping to paint my lower and upper A-arms over the weekend with that paint.
MitchRS
- Sep 20, 2022
- 09 RS Venture GT
Here are the results from the Dupli-Color Metalcast. You need to lay a base of Dupli-Color Chrome or Metalcast Base before adding the color.
I could only find the Chrome paint so I put a couple coats of that and then did 1 light coat of the red and 2 medium coats, my plan was to do 2 light coats and 1 medium but this stuff covers pretty quickly and I wasn't moving the can fast enough. I ended up with a couple runs but nothing major, overall it looks good and I believe it is quite a close match.
Fast Lane
- Feb 6, 2020
- Winnipeg
- Winnipeg
I think my a arms are a bit brighter of a red. I used some Ford touch up paint for my Mustang today. It’s pretty close. Colorado red. I really should pull the a arms are spray them like you.
MitchRS
- Sep 20, 2022
- 09 RS Venture GT
Oh ok, I would have thought that Yamaha would have used the same paint code.I think my a arms are a bit brighter of a red. I used some Ford touch up paint for my Mustang today. It’s pretty close. Colorado red. I really should pull the a arms are spray them like you.
I did a comparison of my painted arm with one of the panels off my sled and it is quite close.
