picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
Years ago I remember a thread about stalling and a way to access some throttle related settings. Any body remember or know about this. I remember there were some values that could be changed. I’d like to check mine and see if they are all stock.
Clamb
- Oct 2, 2016
- Peoria IL
- 02 Sx viper Er 15 sr viper xtx
- Peoria il
Are you asking about the tps system? In diagnostic mode you can check throttle position from 0% to 100%
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
That might be it. Any idea what it should be? And how to get in diagnostic mode? I can’t remember
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
You should be 0 when your not touching throttle and 99-100 when full throttle. I will have to look when I get home but I think it’s with sled power on not started hold bottom left and right buttons and it will pull up diagnostics then scroll threw to tps
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
Also should be checked with bars turned and straight
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
Im sitting here with it right now I’ll try itYou should be 0 when your not touching throttle and 99-100 when full throttle. I will have to look when I get home but I think it’s with sled power on not started hold bottom left and right buttons and it will pull up diagnostics then scroll threw to tps
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
That was correct. I checked it , it was 0 %
If you run any sort of Power Commander it would be a good idea to calibrate TPS on that as well.
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
No power commander for me. I just thought maybe the settings were off. Everything appears to be good. Still isn’t great on startup. Thought maybe this could be why. We put over 1200 miles on last week. It’s not that the sled runs bad. Just won’t stay idling on its own until low temp light quits flashing
How many miles?
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
10,000How many miles?
2015ViperMTX
- Feb 20, 2019
- Iowa
- 2015 viper mtx
Have you had valves checked?
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
Haven’t yet. Had it at a dealer couple weeks ago. They didn’t think it was valves. Not saying they were right though. I’m trying to decide what to do with it. Might broom it.
There's an entire thread about the valves that you should be reading. I'd say high likelihood.
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
I think I’ve seen it recently. Funny, when I dropped the sled off to that dealer I asked them to check that out. That’s when they told me the IAC VALVE WAS BAD. That’s a whole other story. Anyway..... thanks for your input. This forum is really great!
