tds 2018winderxtx
I have 2022 XTX-LE just wondering if there is an accessory plug anywhere. Would like to hardwire a GPS. Is it best to just run back to the battery or is there a plug anywhere i can tap into? I want it keyed to the ignition as I have a habit of leaving these things on…
thanks for any suggestions.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
You can split off the accessory plug at the chaincase used for heated visor.I have 2022 XTX-LE just wondering if there is an accessory plug anywhere. Would like to hardwire a GPS. Is it best to just run back to the battery or is there a plug anywhere i can tap into? I want it keyed to the ignition as I have a habit of leaving these things on…
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
You can use this.
2-Way Splitter,SAE Connector with fuse
Confused
- Oct 12, 2008
- Mound, MN
- '21 Sidewinder LTX SE
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
I need one of these. Have a source?
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Yamaha acc online
