scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Starting to sound even better. You've obviously done your reseach on this project.
mtdream
Srxspec said:The turbo is mounted right off the motor using a cast manifold. The turbo is only 2" or so from the motor for quick spool up. I guess you could consider it a front or mid mount depending on what you call which. The kit includes a new 8.5 gallon trail tank that is molded for clearance around the turbo.
hmmm, sounds VERY good
Topgun
As far as reliability, the kits are all real good turboed or supered. It's mostly rider that determines reliability. Case in point the supercharged Nytro engine I'm fixing at present for someone. detoed the piston , block and head because of boost levels and octane.If you had to run low octane gas your in trouble cause your ALWAYS boosting.yamiboost said:By what you said here "reliability is the key (reliable power) and fit and finish" i would say go sc.
I like the turbo cause if you run into a situation where you need to run regular you have the capability to stay off the boost or stay real low till you can get good gas. The super you can't . Obviously the extra weight up front with the front mount and super is a downfall also.
NLVMAX
- Jan 18, 2008
Topgun said:As far as reliability, the kits are all real good turboed or supered. It's mostly rider that determines reliability. Case in point the supercharged Nytro engine I'm fixing at present for someone. detoed the piston , block and head because of boost levels and octane.If you had to run low octane gas your in trouble cause your ALWAYS boosting.yamiboost said:By what you said here "reliability is the key (reliable power) and fit and finish" i would say go sc.
Would it be correct in saying that a turbo is easier on the motor(reliable) than a SC since the SC is driven off the crank.
adirondac blue
That is an awesome deal, new gas tank, clutching, gauges and the turbo kit for 4500 to 4800.
Topgun
You said it, that is also a pretty well known fact.NLVMAX said:Topgun said:As far as reliability, the kits are all real good turboed or supered. It's mostly rider that determines reliability. Case in point the supercharged Nytro engine I'm fixing at present for someone. detoed the piston , block and head because of boost levels and octane.If you had to run low octane gas your in trouble cause your ALWAYS boosting.yamiboost said:By what you said here "reliability is the key (reliable power) and fit and finish" i would say go sc.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
I would try the supercharger/turbo section to get some serious backup for such an investment. Snowest is also a good source sinc eso many mountain riders run big power. FYI. I also found some great deals on snow west. Lots of guys flipping performance, and suspension parts like crazy. IMO
thetruck454
Oh just what the sled needs! I'm be waiting
NLVMAX
- Jan 18, 2008
mtdream said:Srxspec said:The turbo is mounted right off the motor using a cast manifold. The turbo is only 2" or so from the motor for quick spool up. I guess you could consider it a front or mid mount depending on what you call which. The kit includes a new 8.5 gallon trail tank that is molded for clearance around the turbo.
hmmm, sounds VERY goodcant wait to see that header
Hey mtdream, heard lots good on NW Turbos. How's it running? Lots of miles on now. Is it good for 10 lbs of boost?
Does the kit come complete?
mtdream
NLVMAX said:mtdream said:Srxspec said:The turbo is mounted right off the motor using a cast manifold. The turbo is only 2" or so from the motor for quick spool up. I guess you could consider it a front or mid mount depending on what you call which. The kit includes a new 8.5 gallon trail tank that is molded for clearance around the turbo.
I think there is another forum person that will be able to answer this MUCH better than i...I will give him a chance to respond first
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The sea level setup you want to run 7-8 lbs of boost on premium pump gas maximum. This also requires an additional fuel pump and fuel regulator which adds some cost to the overall kit. We are hoping to have several options for customers of 5 lbs of boost 185 hp into a stock muffler and in that $4500 area. Then 7-8 lbs of boost 200+ hp into an aftermarket muffler and in that $5000 area. Watch the turbo section for an announcement from Ulmer Racing soon!
NLVMAX
- Jan 18, 2008
mtdream said:NLVMAX said:mtdream said:Srxspec said:The turbo is mounted right off the motor using a cast manifold. The turbo is only 2" or so from the motor for quick spool up. I guess you could consider it a front or mid mount depending on what you call which. The kit includes a new 8.5 gallon trail tank that is molded for clearance around the turbo.
I think there is another forum person that will be able to answer this MUCH better than i...I will give him a chance to respond first![]()
Sounds like something is on the horizon?
NLVMAX
- Jan 18, 2008
Srxspec said:The sea level setup you want to run 7-8 lbs of boost on premium pump gas maximum. This also requires an additional fuel pump and fuel regulator which adds some cost to the overall kit. We are hoping to have several options for customers of 5 lbs of boost 185 hp into a stock muffler and in that $4500 area. Then 7-8 lbs of boost 200+ hp into an aftermarket muffler and in that $5000 area. Watch the turbo section for an announcement from Ulmer Racing soon!
Looking forward to the news. Reading the Turbo/ SC section for days now. Lots of good info. May take another few. I'm looking for something 2+ with reliability my main concern.
NLVMAX
- Jan 18, 2008
Just heard that nwturboworks@yahoo.com is no longer making the nytro turbo kit. Another company(Hmmm!) will be making a similar kit and will be using his cast manifold.
I will be staying tuned to the turbo section.
arteeex
