I'm not sure what you are referring to. If all you are trying to do is remove the fuel tank, all you need to do is remove the 2 hex nuts at the rear of the tank. There is also the 1 fuel line on the right front of the tank, the fuel line on the left, and 2 electrical connectors.
im removing everything for inspection due to past mice issues and cleaning it all. i did find two screws at the near tail light. it pretty much came off after that.
