Advice on front suspension
LoneViper
Great Falls Mt
I made the big jump from Mtn Viper to Mtn Vector and this new sled has a definate learning curve for me.
Anybody have any thoughts on the front suspension, Mine seems tippy in the turns and will the Simmons skis off the Viper fit? I measured both spindles and they are 3"
Do you ever get used to the engine breaking? At least you shouldn't where the brake pads!
Thanks in advance for the input.
yes you will get used to the engine braking without a problem. You can adjust your ski's and give yourself about an inch wider ski stance. look at the bottom of the ski's where the arm attaches to the ski. move the spacers on the outside to the inside on both skis and it will give you about an inch more ski stance
I picked up on the ski stance and it does measure out to be about an inch wider stance for sure. It seems like I get a lot of ski lift on a corner compared to the Viper. Could I adjust some of this out with a little softer spring setting on the front. The spring tension is set at 152 mm right now.
The Viper had no sway bar and this does.
