roostinraptor
can someone tell me the easiest way to remove air box.
shadow44
there is no easy way....gage pod, headlight assemby and steering post all need to be removed
Old Thumper
It's really not as bad as it sounds...
mach9
My air box has been out 4 times this year already.
yox185
roostinraptor said:can someone tell me the easiest way to remove air box.
Go to Ulmer's site. In the instructions section there are instructions for installing the K&N filters, which includes air box removal.
Old Thumper
The hardest part was getting to the #3 intake clamp screw. I cut the short leg off a 4mm ball end hex key, so I have a straight 4mm ball end hex about 4" long. Hold that in a 4mm 1/4 drive socket with a long 1/4 drive extension.
mach9
I don't even loosen the intake boot clamps anymore.
I keep clamps full tight, they only go so tight, as there is a stop built into the clamp.
Then wiggle / shove the air box boots on over the TBs.
