rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
lakercr - do you run the NTK sensors on leaded racefuel?
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
rxrider said:lakercr - do you run the NTK sensors on leaded racefuel?
That's all I run. Bosch sensors are a waste of money if you're consistantly running race fuel. You'll be replacing it before too long and wind up within $50 of what the NTK costs, so just bite the bullet now for the NTK...
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Thank you lakercr, I'll have that in mind when my sensor dies. Going to run some unleaded racefuel this season to see what she will do at 20 lbs.
venom
do anyone know if i can use the ntk with the innovate gauge.don't know if it has the same plug.
thanks
thanks
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
ttt
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
venom said:do anyone know if i can use the ntk with the innovate gauge.don't know if it has the same plug.
thanks
I'm almost certain that it will not. FJO is closed today but will be open on Monday. I'll confirm for you and post the answer.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
thanks
It seems like you can.
This is from the Innovate LC-1 Manual:
Appendix A: LC-1 Cable Pinouts
A1. Sensor Interface Connector (Standard DIN-5 female)
Lambda Meter Signal Wire Colors
Bosch LSU4.2
1 Pump+ red
2 Sens+ black
3 Heater - white
4 Pump-/Sens- yellow
5 Heater + gray
NTK L1H1
1 Pump+ white
2 Sens+ red
3 Heater - yellow
4 Pump-/Sens- black
5 Heater + orange
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
My mistake. I thought we were talking about running an NTK sensor other than FJO's on an FJO gauge.
