Air Fuel Ratio Install
5280ft
Denver, CO
I am getting erroneous readings from my WMS O2 Wideband sensor. I` can't seem to get a "green" light.
Has anyone else experienced a problem like this?
The meter starts up and flashes red, then goes to a solid red and a 99.99 reading.
You may have a few wires crossed. Recheck all conections and make sure you don't have any two wires crossed.
1CS
I've been down that road and checked continuity.
I also hooked the positive and negative straight to the battery and received the same results..
What harness, etc. are people using to tie the AFR into the APEX?
I looked thoroughly at a wiring schematic and felt the best would be to utilize the access hot lead, then ground it on the frame where the windshield/multi meter pod frame mounts...
