fixerman519
I was wondering if anyone knows if the 8FT-47489-10-00 SPRING 1 (K=68.6N/MM), will work in a 2015 mono spring apex, the list doesn’t show that heavy of a spring as an option when looking at alternative spring choices , but other members have installed in older units, I am 275 with no gear, I want to send out shock for a rebuild and revolve, would like to get a big boy spring to go with, thanks for your time.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Yes that spring will fit your 2015 apex.
I have some new multi rate springs on the shelf that would work well for you if interested. The advantage of multi rate is you maintain the supple ride on small bumps but have the stiff finish rate for bottom resistance on big hits.
