sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
Hey all well my 2006 vector wouldnt start today so i attempted to pull that hose off and presserize the gas tank.
sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
Hey all well my 2006 vector wouldn't start today so i attempted to pull that hose off and pressurize the gas tank. Well i broke that dang nipple off. Any options or opinions are certainly welcomed.
RobX-1
- Coldwater, OH
If you're referring to this nipple, it's basically a drain plug for the gas tank vent hose to drain out of. If nipple is busted, you will need to find another way to route gas tank vent hose to exit out the underside of the sled.
theCATman
Nipple on tank?? Or which one you talking??
Screw that pressurizing, pop the airbox lid and give each carb horn a shot of aerosol carb cleaner. It'll fire right up.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I have an old primer button and hose from way back. Suck some premix (chainsaw gas, I run ski doo oil in them),pop the airbox lid, spray a full shot down each yap, pop the airbox on (yes, sometimes flames shoot out) and bring the thunder. Usually takes 5 tries before they start sucking on thier own (these 2 havent run since march) Just did my kids' 2 05 vecters.
sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
that's exactly what I'm talking about. Cool thanks a lot man.If you're referring to this nipple, it's basically just plug for the end of the hose to connect into and stay put. Just plug the hose and zip-tie to frame and carry on.
Kenjeepman78
Yup that just gives fuel a place to go if it ever came out the vent tube. Do as suggested you’ll be ok!
RobX-1
- Coldwater, OH
Did not realize the nipple that the gas tank vent tube plugs into was actually an exit for gas overflow; always thought it was a plugged nipple and hence my reply. I edited my post in light of this. Reason being is if you plug the vent tube, then on that rare occasion there is overflow, gas has no where to exit. I suppose you could just remove the plug to drain the gas if didn't want to reroute the hose to dump out the underside like that nipple was providing.Yup that just gives fuel a place to go if it ever came out the vent tube. Do as suggested you’ll be ok!
Kenjeepman78
I’m not sure if that’s the only tank vent if it is you may cause yourself problems down the trail by plugging it and vacuum on the fuel tank. Fuel is rarely going to come out of that line you’d need to be tipped over pretty far. If you have the tools remove the rest of the nipple. Get a smaller hose that slides into the vent line and run it into the opening.Did not realize the nipple that the gas tank vent tube plugs into was actually an exit for gas overflow; always thought it was a plugged nipple and hence my reply. I edited my post in light of this. Reason being is if you plug the vent tube, then on that rare occasion there is overflow, gas has no where to exit. I suppose you could just remove the plug to drain the gas if didn't want to reroute the hose to dump out the underside like that nipple was providing.
sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
ok thanks , i will give it a try.I’m not sure if that’s the only tank vent if it is you may cause yourself problems down the trail by plugging it and vacuum on the fuel tank. Fuel is rarely going to come out of that line you’d need to be tipped over pretty far. If you have the tools remove the rest of the nipple. Get a smaller hose that slides into the vent line and run it into the opening.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Even I'm doing a very small shot of starting fluid instead of blowing into the tank. Works like a dream!
