TrueBlue
What is everyone using when changing all the anti freeze in your system
i have used yamacool (blue), prestone universal anifreeze and the aftermarket blue antifreeze for nissan vehicles with no ill results.
RobX-1
- Coldwater, OH
X2 on the Yamacool.
Mototown
Test the freeze point of the antifreeze, set to -35 F to -40F , helps a lot with over heating onSidewinders
RobX-1
- Coldwater, OH
Since Yamacool comes pre-mixed at 60/40, are you suggesting one still might need to dilute with water to get proper range?
kinger
I am leaning towards trying Evans waterless coolant.
YukonMP
- Dec 25, 2014
- Yukon Territory
That is what I do, diluting with Water Wetter.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I use the blue 50/50 premixed for Asian cars + some Water Wetter.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
The Anti-Freeze debate is second only to the Oil-Debates we "discuss" every year. Lots of opinions.
Here are a few things to consider when choosing a coolant:
1. Stick to manufactures' recommendations on type of coolant i:e Ethylene Glycol
2. Water actually dissipates heat better, but obviously freezes & can corrode or rust components
3. PURE Anti-freeze CAN'T work without water & is 35% less efficient on it's own
4. There are Anti-corrsion additives & inhibitors added to coolants such as Silicates, Nitrates & Phosphates. Some are NO good in certain motors.
5. If water is added, make sure it is Distilled because "regular" water has GOD knows what in it
6. Clean up your mess because dogs can die from licking up coolant & it tastes good to them. NOT a JOKE!
Run a Brand Name 60/40 recommended pre-mix.
If having some issues then drop it to 50/50 with WaterWetter.
P.S: I like dogs!
P.S: I like dogs!
