08nytro87
- Feb 21, 2021
- Ottawa
- 2008 FX Nytro 40th Anniversary Edition
I have been having starter issues with my 08 Nytro. Originally the starter relay fused together and burnt the starter out, a known issue. I replace the starter and relay and sled ran great, riding the trails with very little snow the nytro over heated and the top blew off the res. Let it cool down for a while topped the res up with water (not far from home) and went to start the sled and it wouldn't start. Long story short the brand new starter was dead again, the new relay was fine and functioning as it should.
I have a new starter on the sled again, it's running fine, flushed the coolant and refilled with new coolant. I am still going through the electrical to find and possible bad grounds or any wiring issues.
Now my question, what is this? Through going through the wiring I found this circular circuit board behind the battery that I have no idea what it is.
Anyone have an idea?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
reverse beeper that is missing the cover.
08nytro87
- Feb 21, 2021
- Ottawa
Thank you, mystery solvedreverse beeper that is missing the cover.
Tod
Also rock makes a very inexpensive stuck starter warning that will let you know if your starter is stuck on—— great peace of mind easy install too—- Tod
08nytro87
- Feb 21, 2021
- Ottawa
Thanks, I am going to install a warning light and master power switch.Also rock makes a very inexpensive stuck starter warning that will let you know if your starter is stuck on—— great peace of mind easy install too—- Tod
The second time the starter died on me the relay was and still is operating normally. Any ideas? Possible bad ground?
