UP Michigan rider
- Feb 9, 2013
- Central U.P.
- 2012 Apex XTX
Already had to tow a family members old 1995 Cat through some rough terrain. Rider sat on Cat and steered while I towed him with 12 Apex XTX. Not sure what the combined weight was. Any opinions on potentail "towing vehicle" damage caused from towning other sleds especially towing using the Apex?
Thank you
Thank you
ranger1
Should not be a problem at all towing with an Apex. The only thing I do when towing someone is I change the belt & put an old one on. Towing is hard on belts & substantially decreases the life of them.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Next time tie the tow rope from one ski through your bumper and tie to the other ski. Then have him ride with you, a lot easier pulling empty sled (with the belt removed) IMHO.
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
X2 as little weight on the tow sled as possible...THKSNOW said:Next time tie the tow rope from one ski through your bumper and tie to the other ski. Then have him ride with you, a lot easier pulling empty sled (with the belt removed) IMHO.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
My Apex has towed several blown up Ski Don't XP 800's. Take the belt off of the sled being towed and tie the rope to the ski loop as others have mentioned and pull the sled without a rider. In deep snow you may ruin a belt but on hardpack you will be fine.
UP Michigan rider
- Feb 9, 2013
- Central U.P.
- 2012 Apex XTX
Luckily I had purchased the Steadymate 15543 Snowmobile Tow Strap. It worked great.
http://www.amazon.com/gp/product/B0026F ... UTF8&psc=1
If anyone has any more ideas please post. I'm sure I will be towing again soon.
That is a great idea thank you for that.The only thing I do when towing someone is I change the belt & put an old one on.
Another great Idea thank you.Take the belt off of the sled being towed
stealth800
I towed my buddies cat after he hit a tree 10 miles through hilly trails with him on it because he had to lean to keep the weight off the right side of the sled.Ripped the whole right suspension off his sled when he hit the tree. He was lucky and lucky he had a yammie in his group to tow his arse back to the hotel. Only thing was it finished off my 2000 mile belt. Other than that towed it like a diesel. You"ll be fine, just inspect your belt very closely for signs of overheat.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
Nice tips...I'll do it next time. But I would recommend someone ride it down hills so it doesn't roll into the back of the tow sled.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I towed my buddies 600etec 75 miles after his motor blew at 2k miles. Got another 3,000 miles on that belt after I towed him to boot!
RobWarrior
- Oct 4, 2008
- Western Ma
- 09 FX NYTRO RTX
note the sled being towed on the box is Yellow?
VectorLTX2012
Another trick I've seen is to tie the front of the dead sled to the back of the tow sled. So when riding down a hill you won't need someone on the read sled and the back one tows right in-line with no steering issues. This I've seen done in the mountains.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
CaptCaper said:Nice tips...I'll do it next time. But I would recommend someone ride it down hills so it doesn't roll into the back of the tow sled.
X2, I don't think I'd tow a sled unless there was a rider on it to be able to hit the brakes.
Engine temp will go up slightly pulling a sled,and low speeds. The Towbuddy will be the next purchase for me.looks to make towing a sled real easy going for sure!
Buddy tow .sorrytomanytoyz said:Engine temp will go up slightly pulling a sled,and low speeds. The Towbuddy will be the next purchase for me.looks to make towing a sled real easy going for sure!
