Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Seriously! I thought only skidoo would do something that ignorant. Are you joking?make sure you burp the tank when filling to get in max gal.
Bigbluemachine
- Apr 20, 2006
- NY
- 2017 Sidewinder RTX LE
2011 Apex ER
If I can get 120 I would be satisfied. Where I ride there is gas usually every 100 miles.
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
Racked up 100 miles with 1/8 of a tank left if the gauge is correct.
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Not joking. The tank is under the seat and the back of the sled is higher then the front. Filling the tank leaves air space at the back. Those of us that had vipers know all about it. Fill it to the bottom of the neck then put a knee on the back of the tunnel compressing the suspension slowly as to not bubble fuel all over the seat. Go back and add about another gal. It works best if you have someone hold the back down while you fill it, to get the max amount of space possible.Seriously! I thought only skidoo would do something that ignorant. Are you joking?
Doc Harley
- Oct 17, 2016
- Here & there
Oh yeah.....I've been doing that for the last 8 seasons. Thought it was over. Lol......
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Wow so there is hope on mpg. Had 1/3 tank left after a bit over 50 miles. Did not refill but I had the same amount when I picked it up from dealer and it took 6.5 gallons to top off. Rode through a snow event, 5 - 6" of new fluff!!
Was hoping for more than 1/2 tank left after the short ride, did not happen. Will refill next time out, or maybe forget that one and start over. Ha Ha!
Doc Harley
- Oct 17, 2016
- Here & there
Same boat. Didn't know how much dealer filled. Then stopped to get more fuel. Reset trip, and didn't burp! I'll get it right next time.
PigeonLake
200 miles on mine. 120 miles per tank is what I am seeing with quick trail riding.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I rode with a nytro xtx 1.75 all stock 3-4 feet of fresh off trail 90% of the time he used 8.34gal and I used 8.33 that was in 86 miles so they are very comparable to the NA vipers and nytros I think trail riding will be the same results
Doc Harley
- Oct 17, 2016
- Here & there
Wonder if the gearing in the xtx is same as LTX?I rode with a nytro xtx 1.75 all stock 3-4 feet of fresh off trail 90% of the time he used 8.34gal and I used 8.33 that was in 86 miles so they are very comparable to the NA vipers and nytros I think trail riding will be the same results
If it's geared lower and 1.75 lug. My past experience says the difference is 3mpg +/- vs a 137" with taller gears?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
The XTX 137 with the 1.75 has 21/41 gearing which I believe is the same as the LTX.Wonder if the gearing in the xtx is same as LTX?
