yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Trying to help a friend!!!
anyone know the length of chain needed to run 21/41 gears. From what i understand it's a dropped and rolled chaincase
Thanks forany help
Marc
2018 mtx 153 inch 2.25 power claw has 8 tooth track driver. 21 top gear 53 lower.
Thanks forany help
Marc
Yaahoo
- Nov 23, 2018
- Belmont NH 03220
- 2018 Yamaha Sidewinder LTX 137
Thanks Marc! Ya I Am calling some people this week looks like I might have a lead on what gears to run!! 21/41 isn’t good I guess.
Good guy right there out riding and taking the time to help someone out! Ride on.....
'18 MTX-LE
- Oct 25, 2020
- Wyoming
- 2018 Yamaha sidewinder MT-X LE
Just curious if anything else was determined about the 21/41 gearing? 2018 MTX all stock 3" powderclawThanks Marc! Ya I Am calling some people this week looks like I might have a lead on what gears to run!! 21/41 isn’t good I guess.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
21/41 gears takes a 86 link chain
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
This is for a dropped and rolled chaincase assembly. I beleive the chain is longer then a standard chain on 21/41 .21/41 gears takes a 86 link chain
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
86 link is not correct, the drop & roll of the MTX model makes the chain required longer.
The stock gear & chain setup is 21/52 and this requires a 98 link chain.
If I had to guess, a 21/41 setup on the MTX drop & roll case would need a 92 link chain (looks like the extra length in the center to center distance of the shaft requires about 6 links extra).
lakercr
Tech Advisor
There's a formula to determine correct chain pitch:
(CD x 2)/.375 + (TS + BS)/2 = pitch (round up to even number)
CD = distance between jackshaft & driveshaft centers
TS = Top Sprocket
BS = Bottom Sprocket
For a stock SW (with CD of 10.16") and 21/41 gearing:
(10.16 x 2)/.375 = 54.19
(21 + 41)/2 = 31
54.19 + 31 = 85.19 - rounding up to first even number would be 86, which is what comes in the sled.
Measure your CD and plug it into the formula for correct chain pitch.
TS = Top Sprocket
(21 + 41)/2 = 31
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
The older viper MTX with 21/41 gears takes a 86 link chain, I was unaware that they have lengthened the centers. Sorry my bad
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Quick question
2018 mtx has 3” pitch drivers what gearing change would be required if a guy was to change drive shaft to a 2.86 ?
Track needs replacing and I want to go to a 2 1/2 “ and don’t like options in the 3” pitch tracks
lakercr
Tech Advisor
8 tooth drivers on it right now?
- 32K
