mikeyrules
- Dec 28, 2007
- Earlton,Ontario
- Rs Venture Gt
Anyone seen an Apex 2006 showing a spark plug in the dash,machine runs great at idle,but cuts out at roughly 4000 rpm.
Only once i saw error code 01.
Can this be the throttle sensor(tors)
Help....its snowing here...
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
Are you sure it was a spark plug and not a shock?
mikeyrules
- Dec 28, 2007
- Earlton,Ontario
- Rs Venture Gt
Apex
Ya...maybe your right,it might be a shock.....but it aint a GT
mikeyrules
- Dec 28, 2007
- Earlton,Ontario
- Rs Venture Gt
Apex
I suspect the throttle positioner sensor....hmmm..where do i start...?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
http://www.ty4stroke.com/download.php?id=77941
This link is to the code chart. I am not sure what the difference is between fault code and diagnostic code. Diagnostic code 1 is for the TPS.
mikeyrules
- Dec 28, 2007
- Earlton,Ontario
- Rs Venture Gt
Apex error 01
Turned out to be the drive shaft bearing being worn and touching the speed sensor.All is good now.Thanks totally yamaha...!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Good thing you caught it now and fixed it before you would have been broke down on the trail somewhere.
Replacing this bearing is a common maintenance issue. I replaced mine last year when I replaced my track (along with all of the driveshaft & jackshaft bearings). None of the bearings had failed but I just replaced them all for peace of mind.
