apex4
help...guys....my sled just stared to bog after i rode with my family very slow trail riding....bogging at all different trottles...but not all the time??? Im thinking bad gas.....i am going to add seafoam....but heres the thing i only reecived a code 36 at the end of the ride...gave her all she had........no top end only 114 mph on dreamometer...my sled is alot faster.... so im gonna just pull plugs and change these...any help would be grt
Read this post below. Its for code 35 which is the 3rd coil. Your code is for the 4th coil but should still apply to your issue.
http://www.ty4stroke.com/viewtopic.php?t=44794
apex4
thanks....that maybe all that it is...as sled has power then loses it...and its been on my truck for a week ...bouncing around...i may change plug since ill be looking
apex4
code 36
code 36...is injector?? thats what the service manual is telling me...
According to this list of Error codes it is the ignition coil circuit
http://www.ty4stroke.com/download.php?id=77941
apex4
i must be reading this wrong? when i do the diaostic D1.....it gives me code 36 injector #1 ..Not fault code 36..which is the coil pack
Sorry. Was not aware that there were two differnet types of trouble codes.
Make sure to unplug each coil pack - clean with electrical cleaner-dry-add di-electric grease-and plug back together making sure they are all tite with the sound or feel of the connector click !!
Mine gave me a code 33 once the coil ,the one closest to clutch was just barely in.
Pushed it back in and all is good !
Give it a try.
Give it a try.
Sorry i was not aware as well..should of read a little more..
- 9K
