RobX-1
- Coldwater, OH
lol no. he is the only guy i have seen "flick" a trail width rx war with a 151" track in the powder. he has trail apex front end on his 09 mtx and flicks/tosses it around. his buddies on their back country sleds usually take the bypass and shake their heads when riding with him. heck he looses me on the trail riding either of those sleds if he is in front.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I had a cracked bulkhead on my 06 GT a few years ago and had to replace it. It was a job... but doable.
waternut63
- Mar 22, 2022
- Eden Prairie
- 2006 Yamaha Apex
I have been working on this today. I have another question. How did you get the bolt off of the steering rod that is connected to the steering shaft? I can go the kotter pin and the nut off but now cannot get the bolt out of the steering column. Do I need to get a puller? I applied some hammer force and it did not move. Help?
RobX-1
- Coldwater, OH
If you're referring to this part, I had to replace mine and found heat helped get the bolt out. It's almost like it's pressed on. I even tried a C-clamp but didn't have much luck. When re-installing and since I completely removed the rod, I stuck it in a freezer for a couple of hours and then used heat gun to heat up area around hole and it slid right into place.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Just hit on the side of it with a hammer the vibration will loosen it up.I have been working on this today. I have another question. How did you get the bolt off of the steering rod that is connected to the steering shaft? I can go the kotter pin and the nut off but now cannot get the bolt out of the steering column. Do I need to get a puller? I applied some hammer force and it did not move. Help?
