Apex Enthusiast
Hi! New to TY4stroke, does this clutch operation seem normal? Appreciate any thoughts or advice!
trosell14843
- Nov 17, 2014
- 2005 vector
Hmmmmm. What's the issue? I'll follow this too
Sent from my SM-G935V using Tapatalk
Apex Enthusiast
Seems to be hanging up. Less smooth... There is a flat spot on one of the rollers. How does the action look to you?Hmmmmm. What's the issue? I'll follow this too
trosell14843
- Nov 17, 2014
- 2005 vector
Gesh under power with the belt do you FEEL a lag? Hold up? I wasn't thinking that when I first looked. Though you were concerned for the click out at the max. Thought that was okay
Apex Enthusiast
I wasn't sure. Seems grabby when engaging... Is it common for only 1 roller to have a flat spot?Gesh under power with the belt do you FEEL a lag? Hold up? I wasn't thinking that when I first looked. Though you were concerned for the click out at the max. Thought that was okay
rollers should not have flat spots. take that clutch apart and clean it. i bet it is full of belt dust and it is causing it to hang up. saw an 03 rx1 do this and it partly cured itself when the stock belt blew at 10000km at wot and it blew a bunch of crap and dust out of the clutches.
Zuki1216
- Dec 9, 2015
- Indiana
- 08' Apex LTX
07' Attak MPI S/C
Yeah, looks like something is hanging up to me. Stock clutch? Miles?
Sent from my SM-N910V using Tapatalk
Apex Enthusiast
Stock clutch w/5k miles. It has been sitting for a year.Yeah, looks like something is hanging up to me. Stock clutch? Miles?
had a few apart that sat and i had to steel wool/sand paper the shaft where the busing rides and rollers because of corrosion. worked fine afterwards.
- 47K
