Darren Betker
Ok. Sled sat for 15 minutes in -15° last night and would turn over fine.....i have 0w40 synthetic to thank for with that......but wouldnt fire. Fed up with this issue so i ordered a yamaha red relay.
When it comes in i will let you know how it works.
Irdered two. One for my gt and one for my wifes rtx.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Did the fuel pump run when you turned the key on?
kinger
I have been on a yammie 4 stroke since the Rx1 and I have never had this issue. I don't even know what the red relay is and I thought i knew everything about this sled. Crazy!
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
It's been out for a few years, the electronic relay, no contacts to freeze up. I've replace the old style relay a few times.
Darren Betker
Nope quiet as a mouseDid the fuel pump run when you turned the key on?
Darren Betker
Iv ordered two: 8GN-81950-00-00. 1 for my 06 gt and one for my wifes 06 rtx .i was told this was the electronic replacement fix for the old relay. If this is incorect please someone tell me so i can change the order.
TrueBlue
This is the correct relay & they are Red in color
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
I don't think that you can buy the old relay. No. has been superseded.
Darren Betker
Ok. Thanx
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Was this corrected on the 09's? or should I order one?This is the correct relay & they are Red in color
Winderallday!
If you don't see a relay with a red body on it on your sled, then no. Unless the prior owner swapped it out.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Thanks, I will get Kevin to ship me one right away.If you don't see a relay with a red body on it on your sled, then no. Unless the prior owner swapped it out.
sideshowBob
I don,t believe Yamaha started installing the Red solid state relays on the Apexs until at least 2014Was this corrected on the 09's? or should I order one?
TrueBlue
They started installing the Red relays on Apex & Vectors from 2014-2018
wowchad
- Feb 21, 2014
- Milwaukee'ish, WI
- www.tewco.com
- 2005 F6 - 2009 MXZ 800R - 2010 Nytro - 2015 ACE - 2016 MXZ 1200X
- Milwaukee'ish, WI
- http://usa.cvtech-aab.com
Just had this issue with our 2010 Nytro too and now I need to check the APEX.
Sounds like I'll be ordering these new red solid state relays in bulk
Problem is the 8GN-81950-00 didn't fit in the Nytro so I'm not 100% sure it's the right one.
- 8K
