ddm2016
- Feb 9, 2022
- Michigan
- 2006 Apex GT
Hi guys, I’m working on my 06 apex, 3400 miles, I have put in new injectors, new pressure regulator, can’t figure out why on the number 3 injector it still dumps fuel in the throttle bodies and floods the motor, motor ran before I did exhaust donuts, now it won’t start. Installed a new battery which is fully charged, no codes coming up either. Not sure where else to look. Any ideas?
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
If it's not the injector itself it must be something telling it to stay on like the ECU or a wiring issue. Maybe you disturbed or pinched a wire during the exhaust donut job? Also just go through all the wiring connection points open and inspect, clean, and reconnect.
I would suspect the ECU. It grounds each injector to fire.
ddm2016
- Feb 9, 2022
- Michigan
- 2006 Apex GT
Okay, thanks, I’ll start looking at wiring.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Swap injector with another cylinder and see if problem follows.
ddm2016
- Feb 9, 2022
- Michigan
- 2006 Apex GT
Great idea, I will try that, thanks.Swap injector with another cylinder and see if problem follows.
Did you not state that you already installed new injectors?Great idea, I will try that, thanks.
ddm2016
- Feb 9, 2022
- Michigan
- 2006 Apex GT
Yes I did, that’s why I’m tending to believe a faulty ground wire or ecu. I am in the process of installing a used wiring harness thay my friend and I just today removed from a running sled. That way I will definitely know if it’s electrical, and I also have his ecu to try with the new harness, it’s off from an 07, mine is an 06 which after searching, I believe they are interchangeable up to 2009 or 2010. I should know shortly. Also, grabbed his throttle bodies and injectors. We drove his sled into the garage before removing everything, so I know his wiring harness and ecu are good. I will know later tonight. Hopefully this works correctly.Did you not state that you already installed new injectors?
- 6K
- 11K
