crmac33
I have an 08 Apex ER and was wondering if there would be any gains on top end if I go up a tooth on the top gear? Will I lose much on the bottom or mid? Thanks!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Go with a 23 top it is the same as the attack. It well be faster all over
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
Don't go up a tooth. You will lose out unless you have other mods done to compensate for the higher gearing. Dropping one tooth to 23 will certainly help you out all over.
pdrmike
- Dec 13, 2005
- Berlin, WI / Ontonagon,MI
- 12 APEX'S 09 Venture GT
Unless you play on glare ice I wouldn't recommend, it will be slower. They don't seem to have the power to pull a taller gear on top. My .02
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
you want a 23 top gear in conjunction with a good clutch kit.....proven for best acceleration on this site time and time again.
call Allen.
Dan
call Allen.
Dan
